P0325 Knock sensor code?
Update on thread
I was able to change bank 1 knock sensor without disassembly of intake with a 1 1/16" socket and really long extension and swivel from passenger side of motor, also a second set of hands and a magnet. The knock sensor that came out was definitely not a denso brand but I did replace it with a denso and cleared code then test drove and rescanned and so far so good scantool said all test/IM monitor functions complete and no CEL for any codes so Im keeping fingers crossed. Old knock sensor that was removed I did do the recommended test which was continuity check from connector pin to body of sensor (per TRSM) and sensor did not show continuity but I guess it was bad since all seems good, I want to thank all for suggestions, Jake
