water pump
Thanks Billy. I guess the leak is an old problem that came back. When I was changing out my starter, the coolant pipe that runs from the front to the back of the engine (underneath the intakes) broke free while I was trying to get the rubber hose off the end of it. I actually heard a crack. After I fixed my starter problem, I took a look at the pipe and found that it only had a gasket holding it in, so I put a new gasket on it and reassembled the engine. Well, that pipe leaked like crazy. I took it apart again and used some sealant on the pipe and tried using JBWeld where the pipe came out of the block. I thought I had it fixed then and haven't thought much about it for months. I have had several leaks, so didn't think much about losing coolant. But I fixed the last of my coolant leaks last week and it started leaking real bad through the valley of the engine block(just like it did when I first worked on that pipe). So, I was hoping there was a weep hole behind the water pump because I really didn't want to take out the intakes(for the fourth time) again and tackle that pipe that I don't have a great solution for anyway. I'll take any and all replies because I am tired of chasing this leak.
Went to the Lexus place and got a new gasket. I asked to talk to a mechanic because I knew there was something else wrong I was doing. I spoke with the mechanic and we went back and forth for a while till he said "let me show you a water pump I pulled out today". As soon as he showed me the water pump I knew what was wrong. The housing on my water pump had a section (of where the pipe went into it) missing. Like it was busted off. So now it looks like I will be doing a water pump and I would guess a whole timing belt kit to go with it because I have no idea how long that belt has been on there. So now the new questions begin. How hard is a water pump/timing belt change on these cars? I've done one on a 2003 v6 santa fe- but that is the extent of my knowledge. Are there any good online procedures for the 1995-1996 LS400? Any special tools? Any recommended kits?
It isn't difficult; it's time consuming. I would plan on two full days under the hood. You'll need a torque wrench that's rated high enough for the crank bolt and some method to keep the crank from turning while you torque the bolt. There's a tool you can buy for this that costs about $60, but I used a 2x4 drilled with holes for bolts that thread into the crank pulley. Baggies and a sharpie will keep your bolts organized.
The cams might move a little, but not much. I have a 98 and the pistons are set down in the cylinders while you are changing the belt so there's some free play with the cams without anything hitting a valve. You can rock the cam a little to either side until it lines up with the timing mark on the belt when you're pulling it over the cam pulley. Not sure if the same on earlier versions, but I would think so.
