LS400 won't co-operate
#32
This car is really hacking me off now...
In concert with it's normal party tricks it's now decided that when it does decide it wants to run (usually only ever from stone cold) it also wants to clatter loudly like an old tractor, then drops the RPM to a stall over 30 seconds.
In other news camshaft sensor appears to be responsive and produces the expected waveform (at the time of testing).
Have removed and checked the oil control valve to see if that was affecting the timing. Seems fine.
Struggling to think now what could be causing all 4 cylinders on OS bank to not run.
#33
1996 ls400 no igt1 signal
Tested the igt1 signal and I’m only getting mV. Repaired the ecu and I’m having the same p1300 code.All bank 1 spark plug coils are not sparking and I’m getting Voltage from the ignition coils
#34
