Aftermarket Steering wheel
I have a 96' UCF20. I put a steering wheel on my car and since nobody makes a hub adapter for our cars I used a MKIV Supra adapter, now to make this hub fit you have to remove the clock spring all together.
Only issue with this that I have is no horn, since I dont have a clock spring, I don't have a horn. What can I do for a horn to the wheel itself?
Worse come to worse I will have to install a button on my shifter that is horn. However I would like to retain factory horn button location. Any ideas?
Jesus you hacked it up.
HKB makes 2-3 different hub adapters for the LS, as do several other companies. HKB even makes one that will retain cruise control. All retain the horn and auto-cancel for turn signals. A little basic japanese translating and you can pick them up all day from japanese auctions or US HKB distributors (special order)
Research next time.
Research next time.
Yeah thanks buddy for the useless information. My question wasn't if I could buy another hub. I was seriously misinformed from all the research I already did on this website. After countless searches and a whole bunch of different hubs coming back. And yeah thanks man HKB would be wonderful if They had a website that wasn't 100% Japanese?
On top of that HKB hubs = $$$
My hub = fweeeeeeee. No monies
I used a Grant Hub from work..
Now back to the OP, is there a way or not? Jesus tired of all the people on this site who are just about bashing and not helping.
Alright guess I might have to go back to stock.. I'll peek into maybe a button on the dash/shift ****..
Research next time.
Research next time.
I feel like he was just being plain out rude. My initial question was simple, however he decided to take it in his own hands and tell me I'm wrong. Well here we go, I screwed up but the wheel works, without any issues, aside from horn. I was hoping there is a way that I could install the horn by avoiding a new hub adapter but from what I'm reading and from what yu guys are saying it's a no go.
Sorry if I came off a little rude in return PureDrifter and Mike, however I hope you can see where I am coming from here.
The answer you responded with was way off topic, and doesn't help me in the slightest bit. I'm stuck with the peices I have bro. Nothing else I can do now than drop a couple hundred in a different hub? Or is there a way I can solder a wire to a plate behind my current hub. Let me clarify the Supra hub a bit.
It's a 1 wire design. I am assuming that ground is based on the hubbitself and the wire is the hot (+) wire.
My question is, if I can fab up a small round plate and solder or even melt some wire thriugh it will this make my horn work?
yep i was going to suggest a ground plate, unless your supra hub already has one. i've been successful doing that in my other cars (non-lexus) but that's what the ground plate is for. you just have to find the horn wire in the clock spring harness. there is only one that grounds the relay for the horn to work. attach that wire to the ground plate, and your horn button will do the rest.
the horn is a ground switching system, so when the horn button touches ground, it honks. you just need to complete the circuit at the hub. here is what i suggest (non-lexus but should work if you can find the horn wire in the harness).
http://www.preludeonline.com/f28/how...wheels-206210/
You removed the clock spring, don't get snippy when you ask me how to wire up something that isn't there. The horn is tapped through the clock spring harness. Find a way to make it work or go back and do it properly by reinstalling the clockspring and harness and making your hub work. It's a horn, positive and ground, not overly complex.
What you're asking for isn't the usual way to do things.
Signal cancel works because the hub I purchased sits on the spring loaded back plate with the three offset divets. The only issue I have is from the horn. However, I took a look at that Prelude forum and realized that's very pliable for me to work with and will pull my wheel after work tonight and try itt out if it works props to you Timmy. Thanks man.
But in order for this hub to work for me I needed to remove the clock spring.
Sorry if I didn't clarify that in the OP.
