Wiring diagram for instrument cluster for 91 LS400
I need a pin out / wiring diagram for the instrument cluster in a 1991 LS400.
I need to power it up on the bench so I can see the lights.
Does anyone know the correct wires to connect to power and ground, on the bench? Thanks
Thanks for the diagram....problem is I can't see any detail or blow it up.
Can you email it to me as a pdf or jpg that I can enlarge? Thanks
to: gmach500@gmail.com
Thanks, they are still pretty hard to make sense of....can't see how the cluster is grounded?
Example..D10 (extreme left on diagram) says Door light....is D6 below it the ground for it?
I just want to know how to illuminate the cluster on the bench..out of the car.
Feed power to the whole cluster and light everything up.
Does any one know which combination of plug wires takes power and which ones are grounded?
Wiring diagram for instrument cluster for 93 LS400
Please, you guys has the Wiring diagram for instrument cluster for 93 LS400 ?
ArnoldR
10-03-19 12:21 AM
baxfromNZ
12
06-17-14 10:46 AM
Luxor
01-17-12 08:48 AM
