Replace belt tensioner
Old 02-11-16, 04:59 PM
99LS400DJS
99LS400DJS's Avatar
Default Replace belt tensioner
Well in my infinite wisdom I stripped the bolt on the belt tensioner not knowing it was reverse thread. The car was making an odd noise and I later found out the hearings were all munched in the tensioner pulley.
Anyways, it appears you have to take off the alternator and the pulley in front of the alternator to remove the belt tensioner. Is this correct?
Also, any recommendations on an aftermarket belt tensioner brand or an OEM replacement that won't leave me bankrupt?
Old 02-11-16, 05:25 PM
brybo86
brybo86's Avatar
i think i bought a gates brand tensioner
seems ok so far... only 7k miles on it
Old 02-12-16, 09:49 AM
billydpowe
billydpowe's Avatar
well my manual told me it had left threads, so I just replaced the pulleys.. the manual is really helpful, but a search here would have told you also.. you should try it sometimes
Old 02-13-16, 01:37 PM
sha4000
sha4000's Avatar
I bought a OEM tension off of Ebay last summer and it's been working fine. You don't have to remove the alternator to get the tensioner off. You have to remove the idler pulley to give you room to wiggle the cover off that's underneath it though. Just take a couple minutes to look at it and you'll know what I mean.
Old 02-14-16, 06:57 AM
mikaelse
mikaelse's Avatar
Yeah know that one.I did the same.....
Gates is a good brand. PS the ball bearing is easily exchanged for a new one with a bench wise. buy C3 increased play or it might be too tight otherwise after assembly.
ancdmd
04-16-16 07:03 AM
2jznosht
Performance & Maintenance
19
04-30-13 06:02 PM
A1Lexus
06-07-11 07:19 PM
mtom01
RX - 1st Gen (1999-2003)
17
10-13-10 12:35 AM
poorguy
Maintenance
01-08-04 08:55 PM
Quick Reply: Replace belt tensioner
