Before changing the trans fluid you need to figure out which shift solenoid E is, since if you remove the pan, and don't fix it you will be doing it again. Cam sensor is not related to the transmission codes. The vehicle speed and solenoid are related to the transmission. There maybe others here that have dealt with that solenoid on that year car.
So I've removed the solenoids and there are four. I'm guessing the first solenoid (towards the front of the car) is the lock-up solenoid.
Why can't I find a lock-up solenoid (or solenoid kit) with the four solenoids? When I search A340E, I get lots of kits with only three solenoids.
My transmission has 2 solenoids that are much longer than the ones pictured in the kits.
Any source for the longer, correct lockup solenoid for my transmission?
Thanks again for the help!
Something is bugging me about your car. Your shift solenoid E will not prevent your transmission from moving the car forward. It will only prevent the torque converter locking up / lock it up constantly. I am no transmission expert but I feel that you need to check your shifter linkage, see if it's actually telling the transmission to shift, then throw a pressure gauge on the transmissio to check if the fluid pump is working, and if it is crack open your ECU to inspect your caps before you start throwing parts at it. If your line pressure is low then your transmission wont drive it forward. If your forward clutch is gone it also wont move. Most of all if your ECU is flaky it will not let the trans do anything either. Again don't start throwing parts at every issue that computer tells you is wrong with the car. It can be as simple as wiring problems or ground problems or cap problems. But everything is old and finicky, so take my advice with a grain of salt.
Thanks for the advice. I still haven't been able to get the forward gears to work. The shifter sounds like it's moving the linkage, but I'll get back under the car and look.
Where Can I find the ECU? I've seen posts about re-soldering , so I'll check it out.
