Suspension question
Want to see if anyone has input on replacing front and rear suspension nothing special just to renew for a nicer ride. shocks ,struts,etc
The place where a stronger bushing would be a big plus is the bottom one on the strut, that is a very highly loaded piece. All the bushings on the upper control arm are spherical steel, with rubber covers.
bilstein HD will be stiffer compared to KYB GR-2s (OEM replacements), so bilsteins are best paired with aftermarket lowering springs. OEM shocks are KYB but will be much more expensive!
valex, which non-OEM KYBs did you go with? i've had pretty good experiences with GR-2s, albeit on my non-lexus cars.
ccotenj
Suspension and Brakes
09-01-15 08:30 AM
jgmcs
03-16-07 05:21 PM
