Back Seat
Back Seat
I need to replace my back door courtesy switches and it looks like I am going to have to take the back seat out. Anybody know how the back seat comes out? Do you just push and move up on it? Or better yet know how to get to the back door courtesy switches?
thanks
thanks
You'll definitely need to remove the rear seat. Take the tab covers off, then use a needle nose plyers or somthing to grip the metal tab, and pull the tab back HARD. If you think you've got the tab all the way back then you can also pull the seat up at the same time (if ya can). Once you have the bottom of the rear seat removed, you'll need to remove the 4 bolts that hold the seat back, then the rear seat should be completely out. I think you should be able to see where the rear coustesy switches are at this point, but I can't remember for sure, you definitely have to do all this though.
Earl!
Earl!
