strut tower bar question
Old 04-22-03, 09:09 PM
pongydoo
pongydoo's Avatar
Default strut tower bar question
Anyone know where can I buy strut tower bar for the first gen. LS400?? I heard that we can use the 93-97 Supra strut tower bar with the additional washer, is it true? If it is true does turbo or non-turbo Supra strut tower bar different?? If it is which one should I get (NA or Turbo one) Thanks in advance guys
Old 04-23-03, 07:27 AM
Lvangundy
Guest
Posts: n/a
NO!
I'll be the first one to tell you, the supra strut bar does NOT fit the first gen LS400. There is a slight posibility that the 1993-1994 models could have a different strut mount and it may fit. Hence, SQ-LS says he had one on his 1993.
I bought the STB thinking it would fit (there is much mis-leading information on the subject) and layed it over the mount points. First, the angle of the mount plate is different than the car mount. Second each hole is about 1/2" offset depending on which side you set down first. Yes, the holes do line up but it is not a direct fit.
I have a very credible source to reference on this, and even then it SHOULD be obvious to anyone who attempts to put it on that it's not a direct fit. In my case, I kept the STB and am having it custom fit (cut, re-welded.)
Old 04-23-03, 07:37 AM
SQ-LS
SQ-LS's Avatar
Default Re: strut tower bar question
The TRD is already set and not adjustable. To avoid the problem Lvangundy had I would go with a different bar that you can adjust the length of the cross bar. Plus they are a lot cheaper then the TRD.
Old 04-23-03, 10:02 AM
pongydoo
pongydoo's Avatar
Lvangundy, thanks for the info....i almost bought them. And as for SQ-LS, do you know where can I get the one that can adjust the length of the cross bar. I have always seen the one that already set. Thanks in advance
NebulaGrey
10-14-19 10:02 AM
scstreets
Suspension and Brakes
12-08-12 07:18 AM
troner
11-09-11 04:57 PM
nitto1320
38
07-27-08 03:27 PM
WCSoarer
09-22-06 09:38 AM
Quick Reply: strut tower bar question
