Does anyone know whether there is a separate Toyota/Lexus P.N. for the OEM foam covers and plastic mountic collars that fit over the 4 rear injectors of 1995-2000 LS400?
These serve to attenuate and dampen injector noise.
Images attached
Durable preformed foam cover that fits over rear injectors in 2nd generation LS400
That's funny, I think valve clearance makes more noise than the injectors, or even the poly vee belt.
I would have blown that dirt off much better, the camera sure did a good close up and you sure don't need those little specs getting in the injector.
Does anyone have Toyota/Lexus P.N.'s for these OEM injector covers...Thanks
Go to *******.com with your VIN for any part numbers. Hasnt failed me yet
So the question remains the same...
Does anyone know the Toyota/Lexus P.N. for the foam injector cover depicted in the images contained in the original post. 1998-2000 LS400.
I have already performed due-dilligence with Lexus LS400 parts diagrams and the Lexus parts department.... These older parts diagrams are not always intelligible and have encountered instances where the P.N. on the computer does not match the part ordered.
Meanwhile, the link comes out as*******.com Try providing the URL name without the .com
Based on this diagram (same for 1997 & 2000, I tried both) I'm going to say that they probably aren't sold separate. They make a specific designation for the 4 injectors in the front being "No. 1" and the 4 in the rear being "No. 2" witch in Toyota parts language means that they're two different part numbers denoting that there's something about them different enough to warrant two part numbers and that's probably the cushions.
So, either buy 4 new injectors from Lexus or scour your local junk yards?
