Need help- transgo shift kit install
Hi,
Trying to find info but no sucsess so far!
Car: ucf11 celsior stock 1uz/A341E
Everything else with the shift kit seems very strait foward I brought the 'stage 1' Sk340 kit.
The part I'm having trouble with is the torque converter valve I'm pretty sure. The part supplied does not fit inside the tube that slides into the valve body. But its also too small to simply replace the tube and fit strait into he valve body.
![](http://i65.tinypic.com/24z9noi.jpg)
Original and new !
So what is protruding from the right side of that large valve at the top? Is there a snap ring holding it in?
It looks like that larger New piece is suppose to fit into that large top valve and then the new small valve fits in it?
So you mean there are not instructions that came with the parts? I found information that says there is a video included.
I'm like 90% sure there is no snap ring in the end of the tube at the top but now that you say that I can't actually picture it!
There are instructions but they do not mention the tube at all.
GrayES300
04-19-10 03:44 PM
