Door Actuator
Door Actuator
I'm about to start work on my driver side door actuator. Does anyone know if you can get the door actuator assembly out without taking out the window, or is that mandatory? I've never taken a window out before and am having a hard time finding a procedure that is 95/97 ls400 specific.
In order to take out the actuator, you don't need to remove the window but unscrew the hexa-bolt which holds the rail. Then you can take it out.
