A650E shift kit
taken from this thread:
https://www.clublexus.com/forums/ls-...999-ls400.html
more:
https://www.clublexus.com/forums/ls-...shift-kit.html
more:
I had the TransGo shift kit in my LS for a little while before I swapped to a manual. You can get it through summitracing for under $100. If you have never done any type of transmission work, I highly suggest you getting a shop to install this kit. I also highly recommend you getting a transmission cooler too.
I think I have a wright up somewhere on here, but like PD ^^^^^ said, the SC forum has more info on it.
A650E Shift kit
Has anyone had a 'proper' shift kit from ITP or anyone else ? Seriously thinking of doing one on my LS but would really like to talk to someone who's had one done already... Or if anyone knows anything about them ?....
Nope... I understand to get anything like what I'm after I need a stage 1 shift kit from ITP... I hate the 'laziness' of the A650.... I know thats what its designed to do but for motorheads like me Id love to 'liven' the tranny up... bump up the line pressure a bit and give the transmission some bite... not all this wishy washy gear changes.... ...... Havent got the $$ at present but its the next mod i'll get done.... About $1,000AUD including about $200 freight.... for me, well worth it....
BahHumBug
http://my.is/forums/5903327-post1.html
http://my.is/forums/f88/subject-toyo...y-rods-554241/
They are basically accumulator shims. If you're adventurous you can make your own set with the specs given, or buy a set from ebay. ~$130.
The search terms you want are "toyomoto shift kit" for the is300.
