LS400 crank but no spark! Help!!!!
Old 03-19-16, 10:26 PM
Jessicialp
Jessicialp's Avatar
Default LS400 crank but no spark! Help!!!!
So ive been through the engine with a fine tooth comb. Ive changed everything from the ecu to the fuel pump and cannot get the damn thing to spark!!! Ive read several people having this issue but noone mentions a solution! Help please!
Old 03-20-16, 07:59 AM
sha4000
sha4000's Avatar
What's the year and mileage?
Old 03-20-16, 08:48 AM
Jessicialp
Jessicialp's Avatar
The mileage is 204,000 and its 1993.
Old 03-20-16, 09:38 AM
aptoslexus
aptoslexus's Avatar
Start or spark? Why would you change the fuel pump if you didn't have spark?
Old 03-20-16, 11:24 AM
brybo86
brybo86's Avatar
My car cranked but didn't fire when I had the distributor rotors installed backwards... ? Have you messed with those?
Old 03-20-16, 12:44 PM
dicer
dicer's Avatar
If the igniters pass the test, then next suspect will be the signal sources cam and crank sensors.
And check the simple things too like fuses and relays. If you had a noid light you could check for an injector signal and that should mean the cam and crank position sensors are doing their thing. Maybe Yamae can correct me here or add some more things to check.
Old 03-20-16, 08:14 PM
Jessicialp
Jessicialp's Avatar
Default Still no fix
All the spark plugs are new the coil packs are not firing. There is no spark. I have changed the ignitor modules, crank sensor, both cam sensors, and the rotor( installed properly) and both cool packs. Its turning over perfectly just no spark. And the fuel pump was just cause it was old and im a chick and we do dumb **** like that.
Old 03-20-16, 08:18 PM
Jessicialp
Jessicialp's Avatar
i have changed every fuse in The fuse block are there more i need to be aware of that could contribute to the spark issue im having? This is super frustrating! Im getting ready to run it off a cliff.
Old 03-21-16, 03:30 AM
wchain
wchain's Avatar
Talking
You'd have to be able to start it first....
Old 03-21-16, 04:13 AM
Jessicialp
Jessicialp's Avatar
Question Seriously?
You know i dont need anyone being an unhelful smartass.
Old 03-21-16, 08:08 AM
pmarr
pmarr's Avatar
doe's your model year have a valet key? I once mistakenly used mine to try and start and she'll crank and crank but never fire. Another post in this forum reminded me. Good luck
Old 03-21-16, 01:39 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
Valet keys will still start the car ,if they didn't it would defeat the purpose of having them. The valet keys just don't open the trunk or glovebox locks.
OP: you need to confirm cam/crank sensors and their wiring. Replacing parts at random isn't themost efficient way to diagnose issues like this. YOu may need to bite the bullet and get the car with a shop that knows what they are doing.
Old 03-21-16, 02:12 PM
timmy0tool
timmy0tool's Avatar
have you double checked the spark plug wires to make sure they are in the proper order? they can get crossed at times. also does the car have an aftermarket alarm system? what ECU did you use? from the same year car? just other things to consider.
LOL wow on the cliff comment! posts like that aren't usually found around here, i'm surprised to have read it.
Old 03-21-16, 03:28 PM
pmarr
pmarr's Avatar
My mistake then, I could swear I have a key for my 98 that will do everything but start the car since it has no chip. I assumed this was termed the valet key, my mistake. Thanks! Don't think I have a valet key now that I think about it.....
Old 03-21-16, 06:45 PM
Jessicialp
Jessicialp's Avatar
I havent replaced parts at random lol. I was being fecious. I replaced eveything to do with the issue i have and since im a certified mechanic i usually dont have this issue. Everyone i know is stumped.
Quick Reply: LS400 crank but no spark! Help!!!!
