HELP! I have a (possible transmission) problem with my LS.
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
When I come to a complete stop, say at a red light or something, the car jolts like it kicked into gear except it keeps on happening in 1 second intervals. It did that before but not as much and not as often so i did not pay much attention to it. The car has pretty bad hesitation now and shifts are not as smooth as it use to. When the car is idling I could hear the jolts through the exhaust when I stand outside. There is a slight thump sound that comes out when it jolts. PLEASE HELP!! I suspect the problem is the result of a worn timing belt or maybe the transmission. Has anyone had the same problem? BTW When does the tranny usually go out? The problem got worse dramatically last night. I want to have the problem repaired before something extremely serious happens
Thank you.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Do you know the service history of the car? If you are not certain that the only transmission fluid used has been the Toyota T-IV (the book says T-II, but a later tech bulletin says to switch to T-IV which is synthetic), you may have a hodgepodge of different transmission fluids from various service centers. The LS400 transmission is very picky about the transmission fluids and many owners here have had good results by doing a complete flush and refill with the T-IV. Do a search on this and you will turn up many results regarding LS400 and SC400 with similar shifting problems.
Good Luck and keep us posted on what you try and the results you get,
GA400
GA400
Thanks GA400 for the reply. I changed my tranny fluid with the TIV fluid from the dealer about 3k miles ago. There was little to no change in the car's performance
The complete tranny flush sounds like a good idea though because I only changed the oil with no flush. How would you flush the tranny if you were to do it yourself?
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Here is a link to bananags's diy transmission fluid swap http://lexusmodz.netfirms.com/GS_DIY/completetrans
I wonder if this changes anything but would the problem still be the transmission even if i put it in neutral and the jolts still occur? and also yesterday, i put back the stock intake setup and the problem seemed to be less dramatic.
Moderators, please move this to the maintenance forum where some expert eyes can take a look at it. I don't want to lead LS4zerozeO the wrong way with my "armchair mechanic" troubleshooting.
Thanks,
GA400
Thanks,
GA400
mohep
13
02-21-11 09:58 PM
dann707
06-23-10 03:38 AM
asadchinoy
02-18-07 05:47 AM
1994 LS400
05-26-02 11:23 PM
