Help -emblem seals?
Help -emblem seals?
Hi friends I have a ls400 1993 I'm looking to get the little rubber pieces that go on pins on back of the rear trunk emblem thanks
Super Moderator
The foam seals vary depending on year but they are pretty much the same and should interchange. Take the emblem to a Toyota dealer and see if they can help. If not, there is probably some DIY material that would be useful.
One that comes to mind is the closed cell foam that is used in tool chests as liners. The rubber stamp crowd even uses a similar adhesive type as backing material. Just have to find it in similar thickness.
