hub centric spacers
Location: lancashire /Fredericksburg is an independent city
1 Post
i fitted 30mm ones but can put finger between the front wheel spoke and 4pot caliper so think try 20mm but ? if go 20mm with the wheel studs be too long ie stick out proud of 20 mm spacer ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
how long are the studs ? if i could get wheel i could measure but with disability cant grip the tire iron anymore so
In that case you'll have to grind or cut them flush to the spacer. Just to note, don't overheat the studs when they are being worked on. These are heat treated. Hack saw with bi-metal blade is fine with a few light touches on a bench grinder or hand held grinder to clean the end threads.
1 Post
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/gedc0863_3fd3eebdce2b4d580cc3289707e3aef954f8e69d.jpg)
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/gedc0864_84191253e310646de2621ead169a0cf81d134f0e.jpg)
30mm spacer as multi fit have no recesses on back
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/gedc0865_3961a6ca90a567a46d7502b03b46f0780c38d7cf.jpg)
but they stick out
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/gedc0868_b3451de6dccef5c3e2466eb87e028783d3bbff02.jpg)
would 25mm be better so dont have to short the lugs
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/gedc0866_1838573abfe6bba4547850dd3942a3b82267188c.jpg)
any advice welcome can only learn from ????
1 Post
In Internet slang, a troll (/ˈtroʊl/, /ˈtrɒl/) is a person who sows discord on the Internet by starting arguments or upsetting people, by posting inflammatory,[1] extraneous, or off-topic messages in an online community (such as a newsgroup, forum, chat room, or blog) with the deliberate intent of provoking readers into an emotional response[2] or of otherwise disrupting normal on-topic discussion,[3] often for their own amusement.
that is exactly what your are doing![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
1 Post
Yeah, you're right. Ill get on topic.
In the car modding world your situation is referred to as "poke". It is a desirable look as long as it does not rub or cause any issues. Your poke is aggressive looking and honestly looks cool.
If you don't like the poke you'll have to modify your studs like Timmy said to fit your wheels.
1 Post
