1992 Lexus LS400 - All warning lights simultaneously stay on after starting the car
Hey all.
1992 Lexus LS400. Noticed this problem this morning. After I cranked the engine to start the car, the following warning lights won't turn off and they stay off, even though I don't see anything obvious happening under the hood:
Parking Brake Light - I haven't had issues with my brakes nor any sign they were going bad); no issues using the Emergency/Parking brake either, but engaging and disengaging the brake won't turn it off.
Coolant Reservoir - Checked coolant levels and it looks filled, also checked the temp of my car and it's at optimal levels while it's running
Check Oil - I had my oil changed 300 miles ago
Battery Bad - I changed my battery in February
These lights shut off when I turn the car off.
Any idea what's causing this? Is the alternator bad? I do have a minor power steering pump leak but I've had that leak since I got this car 2+ years ago. I don't have any issues with the lights in my car dimming or my radio cutting out when I drive like I did with my 92 Camry when its alternator was going bad. I don't see the warning lights flickering while I'm driving either.
Help would be appreciated, thanks.
I had the same symptoms last summer and took the car to local Toyota dealer, it was indeed the alternator that had gone bad. I had it changed and all was good again. The explanation to all those warning lights switching on was that those sensor are sending voltage information and when the alternator is bad, the voltage in the system goes down causing the warning lights to switch on.
How many hours of labor do you all estimate for a job like this?
alternator job isn't too difficult so to a competent mechanic, expect to pay about 1-2hr of labor.
however what lead to the failure of the alternator is most likely a leaking power steering reservoir which resides above the alternator. that needs to be repaired as well or you will be replacing another alternator soon in the future. it could be as simple as a $3 o-ring at the bottom of the reservoir.
negative, the rack and pinion is located at the lowest point of the engine bay. you might have a leak on the power steering pump/reservoir as well. when the alternator is removed, you will be able to tell if a PS leak caused the alternator to fail. as i stated, it is very common!
immax01
02-20-12 09:06 AM
poicow
10-08-07 01:05 PM
