Df210 lowering/settling issues
Old 05-02-16, 07:11 AM
Mc96LS
Mc96LS's Avatar
Default Df210 lowering/settling issues
I just installed tanabe df210 springs on my 96 ls400, but instead of lowering the 1.8/1.5 it should have, it's only dropped about 3/4 of an inch all the way around. Anybody have experience with these, or know what the issue is? Do they just need to settle? Thanks!
Old 05-02-16, 09:19 AM
sndlight
sndlight's Avatar
Yes I had the same issue. Took them off after 2 months of no change. Tanabes suck.
Old 05-02-16, 11:18 AM
djamps
djamps's Avatar
I didn't measure my drop but it looks like more than 3/4". The rear OEM springs were already sagging alot so most of the change was up front. I have not noticed any settling over time but I'm satisfied with where it's at.
Did you cut the bump stops down enough?
Do you have springy shocks that might be pushing it up?
Old 05-02-16, 11:23 AM
Mc96LS
Mc96LS's Avatar
Do you have relatively new shocks that might be pushing it up?
The bump stops were cut plenty, and I don't have new shocks either. For me the rear seems to have dropped more than the front. I can't really tell that the front is lowered to be honest, and I wouldn't have even known if I didn't measure.
Old 05-02-16, 11:53 AM
sndlight
sndlight's Avatar
my bump stops were cut in half as well
Old 05-02-16, 11:57 AM
Mc96LS
Mc96LS's Avatar
This is aggravating. The stock springs wouldn't even fit in the box that the tanabes came in because they were too long, so clearly they're lower springs. Were you on stock shocks/struts when you had yours?
Old 05-02-16, 12:07 PM
sndlight
sndlight's Avatar
Brand new KYB in rear and slightly used KYB in front.
Old 05-02-16, 12:40 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
with which shocks?
New springs generally take a few hundred miles to settle in.
Old 05-02-16, 01:04 PM
Stroock639
Stroock639's Avatar
try the H&R springs, they got my ride height pretty much exactly where i want to be. on the OEM shocks btw.
Old 05-02-16, 01:36 PM
Mc96LS
Mc96LS's Avatar
Originally Posted by PureDrifter
with which shocks?
Stock in the front I believe, and kyb in the rear.
Kayasith95
SC- 1st Gen (1992-2000)
07-22-11 09:31 AM
ThomasGS4
40
12-24-10 12:01 PM
ashtray
Suspension and Brakes
51
11-09-10 09:21 PM
SptDsgnGS
07-08-09 12:12 PM
Quick Reply: Df210 lowering/settling issues
