Moonroof not closing all the way
Old 05-02-16, 07:25 PM
shroomysou
shroomysou's Avatar
Default Moonroof not closing all the way
'98 Lexus LS400 with 166K miles.
I hit the auto lever for the moonroof and it will go all the way like it's closing, but then it will go backwards and leave the moonroof open 3/4 of the way. I tried holding down on the lever, but it still goes backwards. I tried holding down the lever for 10 seconds forward and backward, but that didn't work. Any ideas?
Old 05-03-16, 03:24 AM
dicer
dicer's Avatar
Time to use the manual close function.
Old 05-03-16, 04:26 AM
Yamae
Yamae's Avatar
Sounds like the limit switch is not working properly. See attached pdf which includes the wiring diagram and the documents.
File Type: pdf
Old 05-03-16, 07:09 AM
shroomysou
shroomysou's Avatar
Procedure?
Old 05-03-16, 08:58 AM
Tonyucf20
Tonyucf20's Avatar
Procedure?
I have this problem every once in a while. What I do to close it is hold the forward switch on the moonroof and as soon as it closes press and hold the tilt switch. it should freeze the moonroof in place. then i hit the forward switch again and it locks in place.. let me know if it works for you. it works for me
Old 05-03-16, 04:45 PM
dicer
dicer's Avatar
The procedure is in the owners manual.
Old 05-05-16, 08:45 PM
Scraape
Scraape's Avatar
when i was having this issue with my 98 i put WD-40 on the tracks of the sunroof. That fixed it for me, not sure if it was a coincidence or not
mssca
RX - 4th Gen (2016-2022)
16
01-26-18 08:57 AM
kqt2ktval
05-15-09 07:10 AM
irieblue
Hybrid Technology
07-25-08 04:50 PM
FlintRX
05-31-04 07:40 PM
steevr
RX - 1st Gen (1999-2003)
14
04-01-04 06:12 PM
Quick Reply: Moonroof not closing all the way
