Chirping-squeal when in gear
Old 06-11-16, 07:31 PM
RA40
Super Moderator
RA40's Avatar
Default Chirping-squeal when in gear
Ours sits most the time but today we took it for a 30 mile run. As I'm pulling into the garage with the window down I can hear a faint chirpring-squeal when in gear. When placed in neutral or park the chirping sound ceases. Sound seems to come from the front. Will have to check closer, any thoughts what this may be?
Old 06-12-16, 03:04 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
check serpentine belt tension and the clutch fan, may be completely unrelated to the trans just more related to load on the motor.
Old 06-12-16, 10:08 AM
RA40
Super Moderator
RA40's Avatar
Nagged me last night and the top idler pulley has a wee bit of wobble. Everything else felt pretty good as far as what I was bale to tug push on. When the engine had cooled some it didn't make the sound. Something I suspect when warm with load is bringing this on. Past experience with the idler is the 80-90K range the bearing is wearing.
Read other threads from forums where there was mention of water pump, motor mounts and the usual idler and tensioners.
Old 06-12-16, 10:10 AM
python
python's Avatar
Old 06-12-16, 10:52 PM
PureDrifter
BahHumBug
The chirping you're hearing is probably the bearing in the idler, once it gets bad enough to seize the belt will start slipping over the pulley.
The bearings are cheap and relatively simple to swap out, or replace the entire pulley with even less effort.
My tensioner pulley seized up about a year ago at around 180k miles.
Old 06-14-16, 10:45 AM
timmy0tool
timmy0tool's Avatar
how many miles are on your car mike? curious to get a bigger sample of when these bearing seize. i'm almost at 170k myself. hope it's just the idler, which is a simple fix.
Old 06-14-16, 01:04 PM
RA40
Super Moderator
RA40's Avatar
205K miles. Was replaced somewhere in the 90-100K range prior. I'll dig through the past threads to find the bearing size. The last one had plenty of runout and was obvious. This one is subtle so maybe at the beginnings.
Old 06-14-16, 03:35 PM
PureDrifter
BahHumBug
Mine had a "bit" of run-out too...
179k mi tensioner pulley bearing failed on my '99 LS400...
Old 06-14-16, 03:45 PM
sha4000
sha4000's Avatar
PD that looks like the tensioner pulley.
Old 06-14-16, 05:49 PM
PureDrifter
BahHumBug
fixed that
Old 06-14-16, 06:37 PM
RA40
Super Moderator
RA40's Avatar
LOL. I checked it again and it spins smoothly with a bit of drag. Couldn't detect any runout. May have to look along the serpentine belt for other suspects.
Old 06-17-16, 05:11 AM
python
python's Avatar
check the grooves of the pulleys as well as the pulleys that are smooth for residual belt material also
Old 06-17-16, 12:57 PM
RA40
Super Moderator
RA40's Avatar
This thread has similar, going to check the tensioner bearings.
https://www.clublexus.com/forums/per...ngine-bay.html
swilli89
03-28-18 10:27 AM
rns
Hybrid Technology
12-05-16 02:08 PM
djamps
11-03-15 01:39 PM
Toxicxk23
11-14-14 05:20 PM
UR2klose
SC- 1st Gen (1992-2000)
06-09-11 01:39 PM
Quick Reply: Chirping-squeal when in gear
