New LS owner have a mysterious leak, Pics!
Old 06-15-16, 10:42 AM
Benzilla
Benzilla's Avatar
Default New LS owner have a mysterious leak, Pics!
Hello all, New to the forum, avid mechanic but, used to the simplicity of Jeeps.
I found a decent deal on s '91 LS with 101k on the clock. It was being sold with a "power steering problem". It starts, runs and drives very nice, but uses an ungodly amount of power steering fluid.
There is no smoke coming out of the tail pipe and there isn't a leak at the bottom of the P/S reservoir. The leak is coming from the drivers side front bumper,
Heres a picture from the top of where the leak is
Heres a pic from the bottom
I cant figure out if its a P/S Return line or if it has to do with a transmission cooler of some kind
Any help/insight is appreciated
Old 06-15-16, 03:18 PM
Legender
Legender's Avatar
In that area, it has to be the transmission, cooler return line. The PS lines should not flow up there.
Can you follow the line from there to see if it connects up to the radiator?
But then you say you know your losing power steering fluid...what about transmission fluid?
Could have two problems... losing both PS fluid and trans fluid at the same time, from two different locations.
Old 06-15-16, 05:28 PM
dicer
dicer's Avatar
http://www.lexussouthatlantaparts.co...rimLevel=19107
The line group for power steering.
The line group for the transmission cooler.
Old 06-15-16, 05:53 PM
djamps
djamps's Avatar
That's the power steering cooler line. Hopefully it just needs a new hose. The trans cooler is inside the radiator and the lines hook to the back side of it, not really visible from the front where this is.
Old 06-16-16, 02:48 PM
Legender
Legender's Avatar
That makes sense... the transmission cooler lines would come from the bottom of the vehicle and not midway up the engine area as that one does. I stand corrected.
DuckDog
06-27-14 09:33 AM
Sewpra
04-23-14 07:26 PM
whiteshark
20
03-11-12 09:41 PM
ezsls400
06-03-11 11:16 AM
BigMarty
07-27-09 02:07 PM
Quick Reply: New LS owner have a mysterious leak, Pics!
