air cond conversion.
come on folks, I need some help. 25 people looked at my former plea for help and no one answered. I have a 92. ls400. Last year for freon. What parts do I need to buy to convert to the newer stuff. Thanks in advance. Michael..
I had a bad evaporator in my 90 LS400 so i decided to do the conversion since i had to replace it (along with a new expansion valve that was recommended that i replace while in there) also a new drier/receiver which should be installed when the a/c system is opened and finally new o rings.My shop said same price for conversion or leave it R-12.All the parts were there.If you don't want to replace any parts (your R-12 system is fine-o rings are a must i'm told,as the R-134 works at higher pressure than R-12 (also only used 2 lbs freon vs 2.3 lbs or so) HTH!
More trouble than i could deal with
as i'm not really DIY type guy.A local shop charged me 275.00 for labor and i supplied the parts.The local Toyota dealer wanted about 100.00 more for labor only.Others maybe able to tell you how big a job it is.I was glad to fork over the 275.00 to have it done.
Lazy
CL of Southern California
07-02-10 05:58 AM
