New Key programming 98 LS400
1998 LS400
I currently have a master key programmed (Daily use)
i recently purchased a spare 3 button key from ebay.
My question is the following:
I am able to successfully get through section F under B1. However when i get to section G it cycles twice to indicate that the registration was unsuccessful. Any ideas on what could be causing this?
BTW i have already had the key cut and it does open/close doors manually. Also it has already been programmed to start the car. I just cant get the remote buttons to lock/unlock the doors.
any help would be greatly appreciated. I realize that key programming has been discussed in prior threads but i did not see any responses to my exact situation. Thanks
BTW i am using the following to setup the remote:
file:///C:/Users/john/Downloads/wireless%20programming.pdf
https://www.clublexus.com/forums/att...rogramming.pdf
mbryan
03-23-04 12:42 PM
