Intermittent horn
Pushing the horn button on 1999 LS400 did not produce an expected honking...
Not sure if humidity related but encountered a downpour hours before malfunction
However, tried the horn again the next day and it worked perfectly.
So it would appear there is an intermittent issue that merits attention.
Any members experience this issue?
How did you resolve it?... relay, wiring, connectors, actuator button contacts, grounding or ground wire?
Thanks.
Thanks.
Thanks.
Thanks.
Attached is from a JDM service manual but it may be possible for English speaking people to find out where's the horn relay and the pin assignments. The pin#1 is connected the switch at the steering, pin#2 to the horn relay fuse and pin#3 to horns.
Can you post a higher resulution image of the fusebox diagram. Thanks
The horn and it's mounting tab is painted, the radiator surround is painted, as are the tapped holes, and the fasteners are again painted(?) thread-forming screws with lock washer and captive flat washer.
The attached images clearly show a deficient grounding scenario.
I am beginning to think such grounding issues are systemic.
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20160721_150254_9bb1bba415b940b32fb40cfe772053bb425affaf.jpg)
Painted horn mounting bracket side that mates with painted radiator shroud to ground.<br/><br/>Single wire connector
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20160721_150125_a97053f4f6e6e04cec2d00d64af85020c850c416.jpg)
Radiator shroud tapped hole...painted at factory.
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20160721_150315_fae2acdd6ede22e48181232704336a4f1da3ce3f.jpg)
Horn bracket mounting fastener does not suggest optimal grounding between horn and body
The clock spring was functioning
The relay was working properly..
I observed
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20160813_133804_262d386bc3689f8743ed180048f76fdd736d71a9.jpg)
he horn would only work when the telescopic steering mechanism was adjusted all the way in...and both ends of the concentric shafts were abutting up against each other.
So I reasoned the lubricant was insulating the sliding components...
A supplementary grounding cable was fabricated using more flexible 14 gauge fine strand tin-plated marine wire with a #8 and 3/8" ring terminal.
This ground strap was connected at the existing ground strap (closest to driver)#8 screw hole and routed alongside the steering column harness with a loop the loop(permitting extension and retraction) to the steering column support bolt(right of column)
The loop was affixed with a single small cable tie where finger is holding wire loop in image.
Supplementary ground wire installed. Finger is where mini cable tie was affixed.
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20160813_133005_00a4cfdb85726c07aa24408e0e8078bc5b0c4cde.jpg)
To better access this ground screw, slightly bend downward the steering column harness support bracket. I left the original ground wire in place and simply added another at this location
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20160813_132512_338b5548530edd7503b9553530f5ad86e5740489.jpg)
This is where the 3/8" lug was affixed to the body...wire barrel side up serves as a stop to prevent spinning of the terminal whien torquing nut... Horn works better than ever.
imdking (07-29-17)
The normal (original) ground wire spans across the tilt joint pivot and ends before the sliding mechanism...so before adding a ground wire from that point to the body, continuity was inconsistent. Now the horn works.
