Will 19x10 Wheels fit an ls400?
looking at some wheels/cars. Found Rotiforms for 195 a wheel (https://wheelwarehouse.com/collectio...nt=17592559493) But the only size for that wheel that has the 5x114.3 is a 19x10. Too wide?
Oh, I guess if you can't even Google search to find an LS400 on 19x10s then you probably won't search to find out your stock wheels width+offset so you have a base to work off it on the website I linked you...
BahHumBug
Look in the wheel fitment thread stickied at the top of the forum.
The wheel's width and offset determine if it can fit. There are differences in 89-94 and 95-00 fitment. Search the thread, willtheyfit, and rimtuck to get an idea of what modifications are needed to get them to fit.
Listen to PureDrifter. Check out the wheel page int he sticky section. ucf10/11 has different fitment than ucf20/21. That offset is a bit high for how wide they are. depending on what gen you have they might not clear the brakes. best bet is to find someone with similar spec wheels as you want and test fit them on your car to get an idea.
I have 18x9/18x10 on my first gen, around +30~35 heaps of brake clearance for stock 2/1pots, wheels are relitively low disk for the offset. They wont clear 4pots without small spacers. Guards had been rolled as had more agressive wheels on previously.
Mr.Stussy
Wheels and Tires Classifieds
09-06-13 08:03 PM
