Installing LOC onto head unit?
This may sound like a very dumb beginner question, but I'm currently in the process of installing subs in my 1995 Ls400, I'm very close to finishing but the one last problem that I have is wiring up the LOC (Line Out Converter) into my factory Nakamichi radio head unit.
The LOC requires the left speaker (-) (+) wires and right speaker (-) (+) wires. So my problem here is which color wire belongs to which speaker? Some wire diagrams I found online doesn't really help me distinguish the wires and some tell me that there isn't a negative wire.
Also would it be more appropriate to wire the rear or front speakers or is there a way to wire both?
Thanks.
Thanks.
if you're just installing subs then why would you need to tap speaker wires? Did you accidentally purchase a mutli-channel LOC?
The standard method for wiring an aftermarket sub into the LS would involve running the original subwoofer line into the input of the LOC with the output going into your sub amp.
Alright, I'll try run the LOC into the subwoofer line and see how that goes. Thanks for the reply.
I didn't make myself clear, but I am also using an aftermarket amp for the subs. Am I supposed to splice the factory amp wire to my aftermarket amp? If so what'll power the speakers and the LOC since my factory amp will be turned off? I'm not really the kind of person that has knowledge about wiring.
So I'm not sure if I'm thinking the right way, so I'd appreciate some clarification! Thanks.
It sounds like you need to take it to an audio shop and have them set it up. The way it is wired varies depending on model year and if you have a nak or non-nak car.
You will need to confirm but in the '95 NAK cars I believe the AMP only powers the sub, in which case you can wire in one of two ways including one method that eliminates the factory amp. If the amp also powers the door speakers then you would leave all wiring beteen the headunit and amp alone, and simple connect your LOC to the subwoofer output of the OEM amp.
Home theater is the same way. Nevr use a common ground unless your amp/speaker setup is by some miracle set up for that.
Okay its a sound phase thing, sorry I wasn't thinking that, I'm an old school 1 speaker in the old truck guy. It would make a stereo system sound bad having the phases 180 from what they should be, it just hit me. No I have not worked on sound systems. I was relating to test equipment and they can use a common ground. AF generators and such.
FICMrepair
12-27-14 07:53 AM
JamesBond1
08-02-10 11:27 AM
Scott1258
10-12-06 10:24 PM
VSsc400
04-26-04 06:54 AM
