Seat belt retractor
My drivers side seat belt wont retract unless I feed it in by hand. Is it buggered ?.... Can it be fixed if I pull it out or should I just source another one ?
Its very annoying feeding it back in every time i get out... and leaving it out looks very untidy...
I tried this guy's advice on my replacement D/S belt that I'm installing soon and it seemed to have helped the retractability of the belt. It seems to rewind with more speed now.
Seat belt won't retract â— easy fix - YouTube
After a nice drying, the belt feels a lot more pliable and flexible compared to being hard and starch like before.
yeah i guess I forgot to mention, I then dumped out the dirty water (which I couldn't even see the bottom of the shallow bucket) and filled with fresh water, probably about 3-4 times, wringing and soaking the belt each time until the water was pretty clear afterwards.
Hey.. Thoroughly washed the belt in hot soapy water and bucket.. soaked, washed... washed.. washed.. hot water rinse... got it sparkling... honestly i never thought it would work as i was sure the problem was in the mechanism... dried it... and bugger me... the belt works PERFECTLY.... just perfectly.... like new... Wow, you learn something everyday... Thanks for the tip losiracer2... ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I'd say people need to do this every timing belt replacement, every 7 years or so. Auto manufacturers should make this a regimen for cleaning like they do for other wear parts.
