HVAC temp and clock bulbs not working
Old 09-06-16, 12:18 PM
saleenssc
saleenssc's Avatar
Default HVAC temp and clock bulbs not working
1998 LS400 with navigation
My 3 displays right above the navigation/HVAC/Audio screen no longer light up when the interior lights are turned on. Im referring to the ones that show the hvac temp/ clock and outside temp. Im assuming the bulbs are burned. Can these be replaced? any info would be greatly appreciated. I used the search function and didnt come up with an answer to this exact situtaton.
thanks
Old 09-06-16, 03:26 PM
dicer
dicer's Avatar
If there are bulbs they can always be changed if the newer climate controls are like the old ones its a major little deal to do it.
Old 09-06-16, 06:39 PM
Yamae
Yamae's Avatar
I once had exactly the same problem with you on my 98 Celsior. Those bulbs are mounted like these below.
http://celsiorup.com/cgi/ita/file/20...ulti_bulb4.jpg
My local dealer said, "Bulbs for the the navigation/HVAC/Audio are all SMD (Surface Mount Device) bulbs and those are not available/changeable here and we usually replace the whole unit."
What I did was to use SMD LEDs replacing SMD bulbs modifying the circuits. This can't be simply done because those bulbs are SMD bulbs and are also controlled by the dimming circuits. A simple replacement will cause a problem. The detail of it can be found here below but all written in Japanese.
http://celsiorup.com/cgi/ita/itacel.cgi?mode=one&namber=38932&type=0&space=0&no=0
When the link above doesn't work, try this below.
http://celsiorup.com/cgi/ita/file/1453522200.jpg
You can find some more about the bulb. At the post #6, Legender, whom I always find him informative, writes about the bulb source.
https://www.clublexus.com/forums/ls-...ml#post9430921
Last edited by Yamae; 09-06-16 at 09:58 PM. Reason: Too add the link to show how bulbs are mounted.
Old 09-06-16, 09:51 PM
Yamae
Yamae's Avatar
I need to add some more.
I added X: 220Ω, Y: 2kΩ and Z: 1kΩ cutting the trace to get a proper brightness in my application.
There were totally 16 bulbs but I used 20 SMD white LEDs since I used 2 LEDs in series for replacing 4 bulbs used for climate and clock LCDs in order to get a bettter appearance of figures.
Attached Thumbnails HVAC temp and clock bulbs not working-modification-for-dimming.jpg
Old 09-07-16, 05:49 AM
saleenssc
saleenssc's Avatar
bummer..i was hoping it would be a simple replacement. I guess i can live without those windows lighting up at night. Been like that for a few years now and ive kind of gotten used to it. Thanks Yamae for your response.
Old 09-07-16, 03:38 PM
dicer
dicer's Avatar
If you remove the unit, there is probably an electronic repair out fit that can get them going for you, maybe Tanin does those.
dadewi
GS - 1st Gen (1993-1997)
08-25-09 05:11 PM
chas
SC- 1st Gen (1992-2000)
10-25-02 02:23 PM
Taka
11-07-01 08:47 AM
dasenzasian
10-22-01 09:45 AM
Quick Reply: HVAC temp and clock bulbs not working
