brake wear indicator reset?
i've just finished replacing the front rotors & front & rear pads on my 1995 LS400. for some reason, the dashboard brake wear indicator is turned on. i've checked both front and rear sensors, and they aren't worn. i've checked the connections to make sure they are clean, and even tried unplugging them. nothing seems to turn the indicator off.
is there a special process to do this? the pads that i replaced were not overly worn down (i'd say there were about 1/3 of the pad left) and before starting the job, the indicator wasn't on.
help!
thanks
help!
thanks
wierd... i started the car after leaving it for a day or two and the indicator was initially
off, now back on.
arrrggh!! very frustrating & bizarre
off, now back on.
same question actually.mines been on since i bought the car, and all the pads are new. although i am lowered, the one thing i havent checked is the harness in the fender well, apparently theyre very prone to breakage, and getting chewed by the tire when your lowered and the suspension gets fully loaded.
LoveMyES
ES - 5th Gen (2007-2012)
06-14-17 07:24 AM
Revived
02-26-17 07:01 PM
