Oil leak!
11-06-16, 08:04 AM
Oil leak!
replaced the lower oil pan gasket still leaking
11-06-16, 10:52 AM
Super Moderator
From around the pan? How bad? Check the bolt torque again. May have to do the drill again to verify the gasket surface is allowing it to seat properly and or the pan is not damaged at those mating surfaces.
11-06-16, 11:03 AM
11-06-16, 12:07 PM
The lower pan hardly ever leaks unless it's been messed with. More than likely it's the front crank seal. It's really hard to provide any answer to such a vague poorly thought out post however.
11-06-16, 04:09 PM
Is there even a pan gasket there from the factory?
11-06-16, 06:01 PM
Quote:
Originally Posted by
dicer
With the OP's vague-ness, who knows what year he has. But I've never seen a pan gasket on an LS400 from the factory. Just FIPG.
11-07-16, 02:07 PM
Yea I think it's the crank seal anyway to do it without messing with the timing
11-07-16, 02:08 PM
There was no gasket I nope then gasket put one on and my Ls is a 97
11-07-16, 02:19 PM
I really appreciate the help
11-09-16, 01:59 PM
What you meant to ask was:
Ivan7623
Yeah, I think it's the crank seal. Is there any way to replace it without messing with the timing?
Ivan7623
There wasn't a gasket before so I just assumed and installed one. Also, my LS is a '97.
Ivan7623
Thanks, I really appreciate the help!
11-09-16, 06:27 PM
Ivan7623
No.
(filler)
solomaniac
01-31-18 01:55 PM
jaaa
02-18-16 08:28 AM
jayr0422
11-29-09 04:43 PM
GS300chick
GS - 1st Gen (1993-1997)
02-28-05 09:20 PM
