LS400 Manual... Crank but no spark no fuel!?!?(uk)
Hi Guys my Uk LS400 unfinished drift car will not start.
i bought it off a friend that due to illness he has sold all his toys, its 90% through its manual swap running a BMW gearbox and clutch.
before i carry on with the project i just want to hear her running....
so its had the auto box plug bridge done to allow the car to crank.
also a second bridge to display neutral on the dash
it has an uprated fuel pump thats hard wired to a switch so fuel pump is running..
but when i crank i get no spark and no fuel....
ive checked the ecu and it powers up 5v on position 1 12V position 2.
What should i now check!? im at a loss electrics are not my thing,
any help will be greatly appreciated thanks Guys
Ben
Ben
BahHumBug
check the codes per http://www.lexls.com/tutorials/intro/codereading.html
We can't really advise without more detailed information about how the car was wired. My guess is that the ECU isn't getting some signals it needs.
Cars a 1996 it's pre OBD2...
im going to check codes using the guide online after work today and then also check the crank and cam sensors
thanks for your replays guys willl keep you posted
Maybe in some other country a 96 would be pre OBD2, but in the US ALL 1996 cars had to be OBD2, and from what I have read here 1995 is when Lexus did OBD2 on the LS400. So I hope you don't ruin your CAN system trying to jumper like its a 1990.
i jumped it today Te1 to E1 and it did nothing ....
I checked and the diagnostic port does have voltage going to it when ignition is on so don't understand why I got no codes flashing
BahHumBug
Model year designations in other countries is more complicated as the year on the title/rego does not necessarily correspond to the vehicles production year. In the US it's based on when the car was produced, in the UK and (possibly) in Japan, it is when the vehicle was sold or registered.
Update
hey guys little update
so when i go from position 1 to position 2 on the ignition the dash does not light up just some of the lights do this is what it looks like in position 2
as well as the dial pods not lighting up neither does the EML witch is obviously a big problem.
So as you know i bought the car off a co worker he hasnt worked on the car for around 10 months due to illness.
he did have it running but since started gutting the car due to it being a drift car.
he has removed aircon idle control valve is blanked off. and basically started removing wiring thats not needed only wanted it wired as simple as possible...
he thought the wiring was done and that i only need to wire in the fuel pump.... this has not been the case, and he assumes there must be an earth disconnected or somthing. and that i should just go through the wiring Guide "How to wire up a 1uz-fe By Nigel Wade"
whilst messing around with the car today (mainly scratching my head)
i found something interesting out that hopefully one of you guys can explain
in stead of earthing out TE1 because i already know that does nothing i decided to earth out the W pin witch is the cable for the EML light, this is what happened
so not only does my EML now come on but my dash lights up
so i assume the ecu gives W pin a voltage and me earthing it out just illuminates the light, that being said why the hell do my clocks now work haha.
as soon as i pull the earth the clocks go out.
this is the ECU in my car
hopfully i can get thiss sorted soon so i can carry on with the project
thanks Guy
thanks Guy
