Oil leak oh no!!
Old 11-27-16, 02:51 PM
Ls400dan
Ls400dan's Avatar
Default Oil leak oh no!!
hello people, I bought this 94 ls400 about a month ago. I noticed it had an oil leak but it seemed to get worse. Does anyone know what I would need to do to fix this? Also I noticed the bolt there cracked the plastic on there. Thanks guys!
-Dan
Old 11-27-16, 04:39 PM
sha4000
sha4000's Avatar
Looks like your crank shaft seal is leaking. You basically have to open up the WHOLE front end to change it. Change the timing belt and water pump while your in there. It's a big job but doable if your comfortable wth wrenches.
Old 11-27-16, 06:29 PM
dicer
dicer's Avatar
Its not just wrenching, its understanding what proper timing is and proper assembly etc.
Old 11-27-16, 09:00 PM
Ls400dan
Ls400dan's Avatar
i found a how to thread. http://www.lexls.com/tutorials/engine/timingbelt.html
I was worried about setting the timing on the belt and crank pulleys but he stated on how it goes on and where it's supposed to be set so I will be tearing this thing apart in the next 2 weeks when i get paid. I'm going to replace the water pump, timing belt, and thermostat as well. also i noticed there oil all around the block and around the lower half of the motor. could that be just from the fan blowing the oil around? Thanks guys!
Old 11-27-16, 09:17 PM
ejthomp
ejthomp's Avatar
Crank and Cam seals for sure. Just did mine a couple months ago. Change your oil pressure sensor as well.
https://www.clublexus.com/forums/ls-...xus-ls400.html
Other oil leaks? Have you checked the valve cover gaskets? I found mine were leaking, but just tightening the bolts helped stop that.
Old 11-27-16, 09:55 PM
Banshee365
Banshee365's Avatar
Look over my timing belt DIY if you'd like another viewpoint.
https://www.clublexus.com/forums/ls-...-belt-diy.html
Old 11-27-16, 10:39 PM
ejthomp
ejthomp's Avatar
great writeup Banshee!
changing the crank and cam seals is easy when you get there.
BMR95LS400 (12-04-21)
Old 11-28-16, 03:05 AM
dicer
dicer's Avatar
Yeah when the covers they are in are off, can be easy to goof things up prying them out, if that's how you do it.
Old 12-04-21, 01:43 AM
BMR95LS400
BMR95LS400's Avatar
Default Timing belt
GREAT EXPLANATION. Of that process. “That was impressive” thank you for being you.
Russell
Rokas
24
09-22-18 09:35 AM
richfung
02-18-13 05:18 AM
zapola6
08-12-12 02:59 PM
BMWZ3
04-11-10 07:54 PM
Quick Reply: Oil leak oh no!!
