RPM Signal no. 2 help
I have a 91 LS400 with engine code 13 I looked it up says its rpm signal no.2. I don't know what to do next, has anyone had this problem and fixed it or took it to the shop what did you replace?
As you see the chart below, there are two G signals G1 ( cam position sensor 1) and G2 ( cam position sensor 2). Between the G1 and the G2 signals, there should be 12 NE signals sharp. Between the 1st G1 signal and the 2nd G1 signals, there should be 24 NE signals.
Missing signals, insufficient amplitude, noise and unexpected phase shifts are the major causes of the code 13. Failed sensors, a worn timing belt, a connection problem are the major items you need to check. This needs some skills and equipments though.
Slackful (11-21-19)
DriverT
05-06-11 11:31 AM
natdhaeka
08-23-08 03:22 PM
