Oil leak from bottom of engine
Old 12-15-16, 05:19 PM
YODAONE
YODAONE's Avatar
Originally Posted by Hiroshi12
I saw the old tutorial on the LexLs page for doing the job on a 90-94. Any idea how close this procedure would be for a 98?
You should obtain the following parts from Lexus (DO NOT USE AFTERMARKET) when you replace valve cover gaskets;
1) Left and right valve cover gaskets.
2.) Spark plug tube seals quantity 8
3.) Valve cover bolts with rubber sealing washers quantity 18 on 1998-2000 LS400 (sealing washets can be ordered seperate fron bolts, but saves a lot of labor if payong someone.
4.) PCV Valve grommet
5.) PCV Valve
6..).Left and right bank PCV hoses.
7.) Hose clamps for right and left PCV hoses quantity 4.
8.) Spark plugs.
9.) Anti-seize compound for spark plug threads (NOT copper based as used on oxygen sensors!!)
10.) Dielectric grease for ignition coil or plug swire boots interface with spark plug.
11.) If 98+ LS400 be aware the ignition coil plugs connectors are very brittle and prone to breakage...
(Lexus did not use a rubber shroud around engine connectors as was done with 94 and earlier LS400 so heat cooks the plastic dry)
Solution is to carefully remove ignition coil from spark plug tube with disconnecting connector...otherwise Lexus offers replacement connector shells, but will require a tool to compress lances on connector contacts for extraction of wire/contact from original connector shell. (OR ithe wire harness connector shell is often so brittle it will crumble away with minimal clipping with small needle nose pliers or small side cutters and allow you to extract wire with contact intact. Take your time and be careful.to manage wire orientation and not damage contacts.
The existing contact will snap fit precisely into new connector shell.
12.) FIPG (form in place gasket) from Toyota or Lexus (type compatible with engine oil) (use OEM) to be used with valve cover gasket in areas(usually sharp transitions and corners) and the half-moon shaped plugs that are used to fill in at both front and rear of top of cylinder head where machine cut through the head lengthwise in preparation for the camshafts...use a gripping tool to remove. (see # 11183 on exploded parts diagram 1998-2000 VVTi head shown.
Completely cean old sealing compound from mating surfaces. See shop manual for further information.
13.) CRC BRAKE cleaner (red label) to remove all residue from valve cover.
14.) Plastic gasket scraping tool to avoid gouging soft sluminum parts.
15.) Old toothbrush for cleaning surfaces
16.) 10 mm socket -suggest 1/4" drive.
17.) 1/4" drive swivel
18.) Other tools depending upon year...
18.) 8" 1/4" drive extension.
19.) 1/4" ratchet or 3/8" to 1/4" drive adapter.
RA40 (12-15-16)
Old 12-15-16, 05:20 PM
YODAONE
YODAONE's Avatar
5.) PCV Valve
8.) Spark plugs.
10.) Dielectric grease for ignition coil or plug wire boots interface with spark plug.
Solution is to carefully remove ignition coil from spark plug tube without disconnecting connector...otherwise Lexus offers replacement connector shells in case of breakage , but will require a tool to compress lances on connector contacts for extraction of wire/contact from original connector shell. (OR ithe wire harness connector shell is often so brittle it will crumble away with minimal clipping with small needle nose pliers or small side cutters and allow you to extract wire with contact intact. Take your time and be careful.to manage wire orientation and not damage contacts.
Old 12-16-16, 05:59 PM
Hiroshi12
Hiroshi12's Avatar
Thanks for the detailed reply. Guess that's about as close as we'll get to a tutorial?
Old 12-19-16, 08:01 AM
Hiroshi12
Hiroshi12's Avatar
Thumbs up 98-00 VCG Tutorial
http://us.lexusownersclub.com/forums...t-replacement/
Not sure if richardkwon is a member here but if anyone knows of him - thank him for me!
Old 12-19-16, 10:32 AM
Hiroshi12
Hiroshi12's Avatar
Originally Posted by RA40
The itemized amount for the valve cover gaskets on mine was $632. Oil leaking from here isn't a critical running issue, just messy. They will leak more and more as those hard parts allow more oil to get past.
Yeah, I just got another quote today for $615 - including plugs and wires. The tutorial I found ^^^ is pretty comprehensive but......idk...$600 vs a lot of time and frustration - considering I've never done anything on this scale before.
Old 12-19-16, 11:35 AM
RA40
Super Moderator
RA40's Avatar
My motivation to wrench has dropped significantly considering that these guys can do the job about 3X faster than what I would do it at. I've done valve cover gaskets on other cars and it the task isn't complicated in itself. I tire from all the stuff that has to be removed to gain access. This job is about 2 - 3 hours book time, the $600 is well worth it to me because I know I'll make a near full day - 6 hours as a DIY.
One way to learn and completing the task is rewarding. If you have the tools and time...
Old 12-19-16, 06:16 PM
sha4000
sha4000's Avatar
My post disappeared but i used that same tutorial to change mines. It was the Best one I found at the time.
Old 12-20-16, 10:19 AM
Hiroshi12
Hiroshi12's Avatar
6 hours? You da man. I was thinking more like 6 days, a case of beer, broken knuckles and a trip to Toyota for parts I will inevitably destroy in the repair process. Lol
Old 12-22-16, 11:51 AM
deanshark
deanshark's Avatar
Thats what happens when we start getting older. I just had a shop do an easy ball joint on my sons car b/c I didn't want to press it out. But, it was only $150.
Anyway, if you have the shop do your valve covers maybe think about throwing a little more $$ and have the valves adjusted while its open. I wish I adjusted mine when I did my valve cover gaskets (Done in 3 1/2 hours with service manual in hand) cuz that ticking is getting annoying.
Old 12-23-16, 10:22 AM
djamps
djamps's Avatar
'Adjusting' the valves on a 98+ will be alot more than 'a little more $$' because they are not adjustable. lifter buckets require removal of all 4 cams and ordering of new buckets with the correct shimming after very careful measuring (and fingers crossed it's correct). Nothing like the old days where you loosen a collar and turn a set screw. It's basically a timing belt job x2. That said I'm perfectly happy with my minor tick lol.
Old 12-23-16, 01:44 PM
deanshark
deanshark's Avatar
My mistake, I was thinking earlier. Sry.
Old 12-23-16, 02:59 PM
ejthomp
ejthomp's Avatar
Before I spent that kind of money, I would at least try to tighten down all the bolts. Mine was leaking and when I went to tighten some were not even finger tight. They loosen as the gasket compresses. You may just be able to stop the leak.....
jlippard
GX - 2nd Gen (2010-2023)
08-22-19 08:19 PM
John5000
10-06-10 11:54 AM
XYZLexus1
04-30-07 01:30 AM
novalogic8
Maintenance
02-13-05 07:06 AM
Quick Reply: Oil leak from bottom of engine
