95 ls400 odometer issues
Old 12-11-16, 03:34 PM
jerryriff
jerryriff's Avatar
Default 95 ls400 odometer issues
I've got a 95 ls400 that's riddled with problems, one of which is the odometer is not lit up and hasn't worked since I bought the car a year ago. I'm assuming the lights are burned out but I'm not really sure. I can't seem to find any replacement parts or tutorials on this subject. Can anyone help?
Old 12-13-16, 10:01 AM
jadu
live.love.laugh.lexus
jadu's Avatar
moved to the LS forums. hopefully they can shed some insight here.
Old 12-14-16, 12:22 PM
timmy0tool
timmy0tool's Avatar
if the entire cluster is unlit, it could be the very common ECU leaking capacitors.
https://www.clublexus.com/forums/ls-...capacitor.html
Old 12-14-16, 07:18 PM
Yamae
Yamae's Avatar
Are you sure?
The back light is controlled by the independent drive circuit built in the cluster unit and is not related to ECU capacitors.
Of course it's a good idea to replace those capacitors for the better engine running if those are still the original ones.
Old 12-14-16, 10:21 PM
96UCF20
96UCF20's Avatar
Check out this video!
Old 12-15-16, 02:11 AM
Yamae
Yamae's Avatar
If it were for a 95.
Old 12-15-16, 07:04 AM
jaaa
jaaa's Avatar
Originally Posted by Yamae
Are you sure?
Did you watch the video Yamae? I don't think he used the right kind of capacitors for his replacement.
Old 12-15-16, 08:02 AM
Yamae
Yamae's Avatar
Yes, I watched it. You are right, jaaa. He used tantalum capacitors that aren't quite OK for those regulator circuits. Those often cause the phase rotation up to the radio frequency and risk the error amplifiers to oscillate. Also tantalum capacitors are prone to cause the fire risk if the circuit is not designed to use it as is explained here.
http://electronics.stackexchange.com...in-new-designs
We also have to be careful for those who only know the surface of the problem and suggest other people the wrong method. You might be misled by them. I suggest you to ask a real professional if you aren't familiar to the problem or you just study more to fix the problem.
96UCF20 (12-15-16)
Old 12-15-16, 05:29 PM
96UCF20
96UCF20's Avatar
My apologies, Yamae. I thought jerryriff's odometer issue might have been similar to the issue in the video I shared.
Old 12-15-16, 07:51 PM
anesthesia
anesthesia's Avatar
Save yourself the headache and countless hours send it to tanin auto, do a search on here. It's very reasonable and quick turn around.
Old 12-15-16, 07:59 PM
96UCF20
96UCF20's Avatar
That's a great idea! I've posted a link to their gauge cluster repair services offered below.
http://www.taninautoelectronix.com/category-s/1853.htm
Old 12-21-16, 06:10 PM
jerryriff
jerryriff's Avatar
​​​​​​​there are individual lights out on the cluster, I'm just not sure of what I should get as far as replacement lights go.
Stereorob
01-15-23 09:32 PM
lstommy
03-21-19 10:34 AM
saqib
01-06-10 01:08 PM
pletner
03-27-03 06:54 AM
Quick Reply: 95 ls400 odometer issues
