Car sputtering during acceleration and idle
So I just replace the fan pulley bracket before I tore it apart it was running fine. Now it's running really rough mostly during acceleration and cruising not so much at idle. I've tried to see if I forgot to reconnect something or if I hook something up wrong if anyone has any ideas on what it might be please let me know I do not have the money to take it to a Lexus dealer
You might have pinched the wires for the cam sensor while you were bolting the bracket back on. I can't remember if that goes through the bracket or above it. But I would think that would throw a code. Is there any code? Also check the coil wire. On my 93 I pulled on the coil wire too hard, while working in that area, and it snapped one of the clips on the coil so it didn't connect tight enough. Took a while for me to figure that one out. Lift the hood at night and rev it up, see if you can see any arching (sparks) in the area where you were working.
Question
What does the cam sensor look like there is a sensor that only has one wire going into it and does not hook to anything it's like a little grey Square it has a hole for a bolt to go through and then it just bolts to the block I believe the hole where that was mounted stripped is that the cam sensor?
Just above the fan belt in the center of the photo it has one wire going into it no wires coming out you can see where the bolt is in the end of it and it's loose that's because that slot that it goes into broke that's the only thing I could find that isn't hooked up that I could see
I think that component with a single wire is some sort of capacitor to filter out high frequency noise that would otherwise affect FM reception. I remember finding that device once when working on my car, and was surprised to see only one wire, so I looked it up.
So that is not your problem here.
MDSC
Performance & Maintenance
08-04-12 09:11 AM
