1995 LS400 ps pump whine when started at 0F
Old 01-06-17, 10:09 AM
brybo86
brybo86's Avatar
Default 1995 LS400 ps pump whine when started at 0F
frigid this AM in chicago
never had this whine before
fluid level is correct
color is nice and red... not sure how old it is?
whine lasted about 5 mins until engine was warmed up a bit then noise was gone.
im guessing fluid is a little thick at that temp and so the pump had some cavitation?
should I drain and fill reservoir or completely flush the system?
Old 01-06-17, 02:01 PM
monkeyRX
monkeyRX's Avatar
Have this same problem, but not nearly as cold here in SoCal. Any help would be greatly appreciated.
Old 01-06-17, 02:10 PM
RA40
Super Moderator
RA40's Avatar
Has it exhibited this in the past? I've heard some pumps whine a bit on really cold days and 0F is chilly. After a few moments the noise goes away as the fluid warms-circulates. A So. Cal car that has this in 50F would be due to a failing pump and or from reduced flow in the system.
Old 01-06-17, 04:39 PM
dicer
dicer's Avatar
Nothing works good in the cold. And the fluid turns into honey the colder it gets so expect noises that are not normal.
Old 01-06-17, 07:06 PM
brybo86
brybo86's Avatar
never heard it before but I also haven't started the car when it has been this cold either.
Old 01-06-17, 08:24 PM
brybo86
brybo86's Avatar
Update I just checked the level , it is 3F outside and it is right on the bottom end of the cold section on dipstick. I added a tablespoon of ATF and it quieted down. Hopefully not a leak(I don't see any) maybe just cold fluid contracted enough and a tiny bit of air got in?
Old 01-07-17, 03:32 AM
YODAONE
YODAONE's Avatar
Default Power steering pump fluid
Zero Fahrenheit is common temperature in Chicago...with windchill factors in negatives...
While engine oil reaches operating temperature in short order, I am not sure the P.S. fluid.ever reaches optimum operating temperature...and pushing thick 0 F Mercon III ATF is hard on the P.S. pump.
My 1999 LS400 P.S. pump was replaced with new Lexus part due to noise and beginning leakage.
.Does anyone know if Mercon III ATF is considered "synthetic" or if not, what synthetic brand product would apply....looking to replicate good low temperature results using synthetic engine oil.
I use 0W-30 Mobil Synthetic engine oil and cold start is effortless at 0 F.
Old 01-07-17, 11:21 AM
RA40
Super Moderator
RA40's Avatar
Mobil 1 ATF is a full synthetic. Mercon III is petroleum based from what I've read of the formulations.
Old 01-09-17, 11:18 PM
GH5T
GH5T's Avatar
23F here in MD. warmest its been all weekend
Old 01-10-17, 02:44 AM
YoshiMan
YoshiMan's Avatar
My current 2008 Sequoia, and my 04 GX470 i used to own do/did same thing for a few seconds when being started on the days where it's below 0. I wouldn't get too worried about it.
larryhirs
04-29-24 05:41 PM
Mtdave2
23
08-17-14 11:44 AM
MyGS3
GS - 1st Gen (1993-1997)
14
03-04-14 09:00 PM
billj747
16
01-21-08 10:53 AM
tbilisi79
16
12-25-07 10:42 AM
Quick Reply: 1995 LS400 ps pump whine when started at 0F
