adjust 91 ls 400 driver headlight
The driver side headlight assembly was damaged and the PO attempted to adjust the headlight to compensate. I have realigned the assembly and now the driver, left low beam is way out of alignment. It angles right and down. I was able to adjust the up down by many turns on the adjustment screw. (It is the one closest to the radiator.) What remains is to angle the light left. It appears to be at least a 1/4 inch out or alignment. I have tried to adjust the left/right screw but it does not appear to have any effect. Before I go to far and break something that may still be working I would like to know which way I should be turning it to adjust the light left? Should it be clockwise or counter clockwise? I have looked through many searches and found no reference to the adjustment turn.
Thanks in advance.
Dan
Thanks in advance.
Dan
triplecore
09-03-06 06:42 PM
