Overdrive clutch sensor replacement 1992 ls400 code 67
Old 01-09-17, 10:59 AM
92LS1uzfe
92LS1uzfe's Avatar
Default Overdrive clutch sensor replacement 1992 ls400 code 67
Just got done replacing sensor that is located above cat. Converter in housing of transmission on driver side. Will need to remove 2 heat sheilds by front of tranny.the lower one first then upper one need 10 mm. Socket and universal joints. The area is tight but doable. Check harness to make sure you have good contacts. Could be loose connection. Hope this helps. My car now kicks into overdrive and is so fun to ride. UCF10.
nms169
04-06-23 05:05 AM
SilverJade
11-24-13 06:32 AM
yanivsme
07-05-12 11:56 PM
billy boi
07-15-05 07:14 PM
slash
03-05-05 05:48 AM
Quick Reply: Overdrive clutch sensor replacement 1992 ls400 code 67
