Parasitic drain while parked - solved
My 91 ls400 had a trunk light staying on with the trunk closed, due to a faulty CD player providing a ground for the light. Apparently, the cd player needs to know when the trunk is open, I suppose to prepare for removal of the disk cartridge. What ever they were thinking 25 years ago I can't say. Unplugging it corrected the issue, but I opted to physically remove it as well. I was shocked at how much the beast weighs. No wonder this car weighs so much. Even though they used a lot of aluminum for the time. If I had removed this much unneeded weight from my MR2 I would throw a party.
CELSI0R (01-15-17)
I used to have a 92 that developed an overnight drain. It drove me crazy, and I was thinking about putting a disconnect on, but that makes the car forget so many things. One day after pulling a fuse at a time, I narrowed it down to a minor circuit but still couldn't see anything on. I finally turned off all the lights in the shop, and found the passenger visor mirror light was on, and you can barely see it when it's closed. I just had to work the switch a little until it started turning off again. Simple fix, but not so easy to find. So if you have a 1st-gen, especially one with lower miles, you can check those kinds of things that have power all the time.
OkieLS400
10-21-14 12:14 PM
wcoastls
02-12-11 07:16 PM
green96es
12-08-03 11:00 PM
kylesc400
SC- 1st Gen (1992-2000)
03-09-03 03:44 PM
