1998 Fuel Tank capacity
Old 01-23-17, 02:22 PM
hms09
hms09's Avatar
Default 1998 Fuel Tank capacity
Couldnt find it in the owners manual so does anyone know what the fuel tank capacity is on a 98 LS400??
Thanks
Old 01-23-17, 02:37 PM
winter4w
winter4w's Avatar
Thanks
It is ​​​​​​​22.5 Gallons. Here is a list of Specs for the LS400 http://www.lexls.com/info/ls400gen2.html
Old 01-23-17, 02:58 PM
Stroock639
Stroock639's Avatar
22.5 gallons
for something like this wouldn't you rather just google it and get an instant response rather than having to wait for someone to reply?
here you go
http://lmgtfy.com/?q=1998+ls400+fuel+tank+size
Old 01-23-17, 03:01 PM
hms09
hms09's Avatar
Google is great but I only trust you guys for correct answers.
BNastee (07-29-19)
Old 01-24-17, 12:39 PM
sha4000
sha4000's Avatar
This is on the back page of the owners manual.
Old 01-24-17, 07:25 PM
Kdfwagen
Kdfwagen's Avatar
I still don't believe it's 22.5
Old 01-25-17, 01:27 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
And this would be because.....?
22.5gal per Lexus.
https://www.clublexus.com/forums/att...998lsspecs.pdf
Old 01-25-17, 09:26 AM
winter4w
winter4w's Avatar
lol why is that? If you want to prove it yourself get your car low on gas until the light shines and fill her up. The pump will show 20-21 gallons of gas in her (Don't drive the car empty). Also the manual says its 22.5.
Old 01-25-17, 09:45 AM
pmarr
pmarr's Avatar
Can just about confirm. Ran car for 15+ miles on low fuel light. Filled up next morning and was able to put 20.8 in so I believe it
Old 01-25-17, 02:49 PM
Stroock639
Stroock639's Avatar
what's sort of annoying is that once you drop below like 27 or so miles of predicted range it just says LOW FUEL instead of continuing to give you range. one time i reset the trip computer once this came up, and used the trip computer to just slowly drive around until i got to what i believed was about 0 miles (i normally never let it get below 1/5 of a tank so please don't tell me it's a bad thing to do, i know it is but this was for science lol) and even then it only took like 21 gallons, the car wasn't actually showing any signs of being about to run out (coughing, sputtering)
someone correct me if i'm wrong but for whatever reason i think the 2000 LS 400 only has a 21.9 gallon tank, never understood why that was
Old 01-25-17, 04:44 PM
winter4w
winter4w's Avatar
Yes the 2000 LS400 has a 21.9 gallon tank (https://g.co/kgs/heFraf)
Old 01-25-17, 09:11 PM
PureDrifter
BahHumBug
http://web.archive.org/web/200911221...000LSspecs.pdf
Correct, 21.9gal for the '00 model. It was likely due to the enhanced EVAP equipment present for that model year, specifically addition of the ORVR (on-board refueling vapor recovery).
fastegg
17
08-22-11 12:45 AM
qewani1
13
04-14-09 10:17 PM
UofACATS
16
05-30-08 02:46 PM
gsWarrior
Maintenance
06-01-05 03:10 AM
Luchini
12-17-02 03:45 AM
Quick Reply: 1998 Fuel Tank capacity
