Oil change dilemma?! Please help?
So my ls400 has been maintained excellent over its life all records I have. The last 2 oil changes were 6/1/2015 at 140,000, and 11/11/2015(mileage wasn't indicated on sheet, someone got lazy). I can only assume 143,000 miles. I bought the car with 144,000 it now has 145,000. The oil I believe used is mobile 1 synthetic. Although it hasn't been 20,000 miles since the last oil change its clear the oil/car has done some sitting as the car has only aquired 6,000 in a year and a half. Taking it in to get a oil change tomorrow should I be worried about anything have shortened the life span of the motor??
I run 7,500 mile intervals with Mobil 1 5W30. You're fine. Use an OEM filter if you can.
x2 for mobil 1. I run 10w30. OEM filters are good or mobil 1 filters are rated good, they even have the extended performance ones that they say will last 15,000 miles.
