Glove box lighting ls400
Old 02-02-17, 08:10 PM
YODAONE
YODAONE's Avatar
Default Glove box lighting ls400
The glove box lighting module uses a wispy T 1-3/4 all-glass wedge base bulb that does not provide adequate illumination.. The fit of the incandescent bulb is so tight that the only glass envelop that seems to fit into the socket is the OEM bulb. Superb molding job by the OEM supplier, but as discussed in other postings on interior lighting, black is a poor reflector of light...
So to improve the siuation, I applied high temperature outdoor rated aluminum foil tape with high surface energy pressure sensitive adhesive to the bulb cavity..
Like night and day..
Image of the bulb assembly post extraction with the grill opened. Grille and bottom half is molded as one piece so mind the thin plastic hinge and direction it swings open...on the connector side.
THIS POSTING IS INCOMPLETE...AND IT WILL REMAIN SO.
TO WEBSITE ADMINISTRATOR....SPENT OVER AN HOUR ATTEMPTING TO UPLOAD THIS POST AND HAVING TO CONTEND WITH INCESSANT POP-UP ADS ON YOUR WEBSITE...AND INFORMATION THAT DOES NOT UPLOAD OR DISAPPEARS WHILE DOING SO REQUIRING REPETITIVE ENTRIES...WHILE I WAS INFORMED TELEPHONICALLY THAT THE SITE PRODUCES REVENUE FROM ADS., WHY SHOULD I OR OTHERS HAVE TO ENDURE IT WHILE POSTING CONTENT THAT ARGUABLY DRAWS VIEWERSHIP AND AD REVENUE??
Old 02-03-17, 09:33 AM
2KHarrier
2KHarrier's Avatar
Nice write up Yoda. Your efforts are appreciated here!
ngipay
GX - 2nd Gen (2010-2023)
07-15-23 05:55 AM
johnnylt
08-21-18 09:20 AM
DAgreenSC
SC- 1st Gen (1992-2000)
09-27-07 11:09 AM
ARISTO 161
12-15-05 05:17 PM
Quick Reply: Glove box lighting ls400
