Engine oil dipstick -o-ring replacement
Old 02-15-17, 10:46 PM
YODAONE
YODAONE's Avatar
Default Engine oil dipstick -o-ring replacement
The dipstick (item # 11452) in our LS400 has a rubber o-ring where it joins with the number one oil pan: item # 12101 in exploded engine parts diagram.1998-2000 LS400 engine block depicted
I obseved a greasy fuzz at this junction suggesting the rubber o-ring needed replacement..diagram item #.11452B Lexus P.N. 9672119010 (1998-2000 LS400) 9671119010 ; 9671001010 (1990-1997 LS400) Upper oil pan, oil dipstick tube...
Hauled engine showing dipstick tube...Easy to replace like thiis but requires patience to extract and reinsert when engine installed..
I removed the battery, battery tray and unbolted the fusebox to better access the bolt holding the oil dipstick tube to the head...
Image depicting oil dipstick tube insertion point on oil pan and mounting ear and bolt.
Old 02-16-17, 09:04 AM
billydpowe
billydpowe's Avatar
I am not understanding the reason for this post??? are you just needing help, or what??
CELSI0R (01-06-21)
Old 02-16-17, 10:04 AM
YODAONE
YODAONE's Avatar
So, this is a project that I completed...
The hauled engine image was used because almost impossible to photograph the areas to access for replacing the dipstick o-ring...
You can read there was evidence o-ring was leaking?
Also, if oil leaks, then strong likelihood engine PCV vacuum leaking past o-ring as well...
The original o-ring was brittle and and cracked apart on extraction...not sealing oil or vacuum in..
Another thing...because unbolting and slightly moving fusebox (accessin inside the fusebox by removing access panel is required) on 99 LS400 to make room to access dipstick mounting ear bolt, I elected not to provide images.....
Not encouraging first-time do-it-yourselfers who may elect to bypassing removing battery first..
Someone else wants to post those pictures...feel free.
Old 02-16-17, 10:20 AM
lextout
lextout's Avatar
was never a fan of the post UZ oil filters
Old 02-16-17, 11:30 AM
YODAONE
YODAONE's Avatar
This post is concerning the Oil Dipstick tube o-ring seal where it inserts into engine... Not at all referring to an oil filter...I have cropped earlier photo to better direct your attention
aymad
07-19-18 06:56 PM
additude
11-14-17 10:25 AM
Elless400
15
10-27-17 12:16 PM
Joefish331
05-20-16 07:21 PM
Quick Reply: Engine oil dipstick -o-ring replacement
