Hello, will 2000 GS300 wheels 17 inch fit on my 98 LS400. I want to make sure they clear the brakes. Thanks.
Chances are, probably not. You'll run into the same issues with my SC430 wheels. Even though you only need a minimum of 16" to clear the rotors, you'll need at least a 20mm spacer to clear the calipers. I used these for my SC430 wheels and they're working great.
I know they won't. I had some 16's from the GS (same offset as the 17's) My friend had the '98 LS400, he wanted my wheels and we did a test fit. The wheels lineup but LS brakes got in the way.. So Nope.
