1 Gen LS400 - Take out the yellow fog glass
Old 05-28-03, 10:41 AM
ychachad
ychachad's Avatar
Default 1 Gen LS400 - Take out the yellow fog glass
The thinking at the time (late 80s) was that yellow light helps one see better in the fog. Although that theory is still true, the LS400 fog lamps were simply covered by a yellow glass that reduces its lumen output by 50 percent!!! This problem was later fixed in the automotive industry by using a bluish tinted glass that produced yellow light, but did not reduce its efficiency. So I broke out the yellow glass with a whack from a screwdriver and voila!!! What a difference. The beam is so much brighter, and the pattern is more accurately placed as well. The yellow glass was of very cheap quality, and not optical quality. This should also reduce the heat build up in the lamp and make your expensive bulbs last longer. Go for it.
Old 05-28-03, 02:04 PM
retrodrive
Search Function Inc.
retrodrive's Avatar
Yeah, I have done it long time ago also.
Old 05-28-03, 04:35 PM
Jasoneo5
Jasoneo5's Avatar
Thanks so much!
Old 05-28-03, 04:58 PM
2jzgte
2jzgte's Avatar
How do I do this? Is it legal?
Old 05-28-03, 05:00 PM
LOTC
VIP 様式
LOTC's Avatar
White foglights at night, much better than the traditional yellow.
Attached Thumbnails 1 Gen LS400 - Take out the yellow fog glass-mvc-058f.jpg
Old 05-28-03, 05:25 PM
ychachad
ychachad's Avatar
Perfectly so!
Old 05-28-03, 11:34 PM
persian451
persian451's Avatar
what kind of bulbs did u put in the fog lamps?
Old 05-29-03, 12:42 AM
LOTC
VIP 様式
LOTC's Avatar
A very hard to find H3C bulb.
Old 05-29-03, 12:45 AM
retrodrive
retrodrive's Avatar
Old 05-29-03, 06:54 AM
ychachad
ychachad's Avatar
Get a H3C bulb easily at the Lexus dealership for $22.00 each.
Old 05-29-03, 08:26 AM
LSPiNoY
LSPiNoY's Avatar
so do you knock out the yellow glass with a flathead screwdriver? or do you disassemble it?
Old 05-29-03, 08:40 AM
ychachad
ychachad's Avatar
Just pound it and break it with a screwdriver. Make sure you do not damage the metal housing, as it will destroy your beam pattern.
Old 05-29-03, 04:59 PM
2jzgte
2jzgte's Avatar
But is the yellow glass behind the clear glass? i don't get it TWO layers are in there? I don't want naked lights.
Old 05-29-03, 05:11 PM
retrodrive
retrodrive's Avatar
OK. I see some confusion here. The best way to do it is take out the fog lights (have to take out whole assembly...need a howto?) and you will see that the part with the yellow glass is held in by 2 screws. You can remove the screws, take out the yellow glass part with a metal frame it sits on and brake it outside of your fog light (so no glass stays inside). Then put the frame back in and you will have your clear light.
Old 05-29-03, 06:10 PM
LSPiNoY
LSPiNoY's Avatar
when opening the foglight assembly, will it increase the likeliness of moisture on the inside of the glass causing yellowness?
Quick Reply: 1 Gen LS400 - Take out the yellow fog glass
