How to remove the ECM
Old 04-15-17, 11:48 AM
Georgebob
Georgebob's Avatar
Default How to remove the ECM
I'm trying to remove the ECM from a 1996 LS 400 in order to have it refurbished. After removing the glove box, I removed the nuts from the lower mounting bracket of the ECM. However, I'm not sure how to access the nuts to the upper mounting bracket. Do I also need to remove the CD box in order to access the upper bracket mounting nuts?
Old 04-15-17, 11:57 AM
TREYFIGGS
TREYFIGGS's Avatar
I don't know about that year but I just did this on my 90. And you had to remove the glove box liner in mine. I just need to figure out if I have to get it flashed/reprogrammed if I swap the ECU. you happen to know? Why you replacing yours, just curious?
Trey
Old 04-15-17, 02:33 PM
Georgebob
Georgebob's Avatar
Have had intermittent engine problems. After several trips to the Lexus dealer, they now think its the ECM, but they're not sure. They gave of quote of $1300 to replace it. So hoping I can just remove the existing one send it off to be refurbished.
Not sure about whether this will be a problem with my key remote (e.g. FOB).
Ajd43
04-26-18 12:02 PM
Georgebob
04-24-17 07:16 PM
rickmlexus
08-09-11 10:32 AM
jasonlina
04-15-05 12:04 PM
Ali SC4
SC- 1st Gen (1992-2000)
11-25-02 11:25 AM
Quick Reply: How to remove the ECM
