Question about bad fan clutch bracket
So I know the bracket is bad itself, but I was wondering to replace it do I need to remove the serpentine belt or anything. This is my first Lexus so I just figured id ask before I screw it up
This is a glorious link to click/tap if you have a 95-97 https://www.clublexus.com/forums/ls-...-belt-diy.html
I think it's almost, if not, identical a procedure on a 90-94, too, but I'm not sure.
Excellent info with torque specs in this DiY. Well written.
If you hit any snags, I just did this job, replacing other items while I was in there, so if you have questions, I may have answers.
Also, the two front engine-facing ac compressor bolts need to be removed/loosened as they tread into the fan bracket. That part is reportedly a pain but I found it to be much easier than I was lead to believe. To be fair, I have a decent tool collection.
http://www.lexls.com/tutorials/engine/timingbelt.html
Watch this video repeatedly if necessary to get feel of the layout around the fan bracket. Then go back to the other link and focus on the fan bracket stuff only.
That is a good tutorial for the 90-94 T-belt. Just follow that until you get to the fan bracket.
The problem with following the DiYs strictly, word for word, is that you'll do unnecessary work.
For example, the rotors, caps, housing..none of that needs to be touched. Nor does the alternator.
So, while these write-ups are incredibly helpful, use your own judgement as well, and skip what you can.
Unfortunately, having done this myself (replacing fan bracket but not T-belt or anything else) during an unplanned emergency repair, I'll say that there are not many steps that can be skipped in this case. If it looks like you can definitely skip it, you probably can. If it looks like you might be able to skip it, you almost certainly cannot. That fan bracket is buried deep.
Also, I did mine on short notice and had to go and get the part from a local store, O'Reilly's. It was a Dorman part, and it was not an exact match, so I had cut off some of the casting to make it fit. So match up old with new before trying to get the new one to fit, otherwise you might be like I was and end up having to take it off to see why it's not fitting on there.
Of course, if you've got the time and budget to plan, this would be a good time to replace many of the other components you'll be exposing. But if you are new to this sort of stuff, it may not be a good idea to do the full timing belt replacement right now.
Yes, good advice. If you can find steps to skip, hold off on doing them until you're sure you have to do it.
When you arrive at your destination, replace with an OEM Aisin brand fan bracket bearing...obtain from Toyota/Lexus or Rock Auto.
There is no excuse for a new part that does not fit...remove it and return it to O'Reillys....
Makes you wonder what else about the part is not right....such as bearings...
The good guys at O'Reilly's were sympathetic and offered to take it back. But I kept it since I needed to leave on a trip, and I think they gave me some sort of discount or something.
At this point, it has been 6 years and 20k miles without any problems, and it is not coming off until it fails. If I'm in there doing a T-belt one day, I'll probably give it a thorough inspection.
I agree regarding the "what else could be wrong." The bearing felt good. The price I paid was not especially low, so I don't think Dorman was trying to make an ultra cheap product. And other than the bearing, and having it fit, there really is not much to the fan bracket. But really, it was kind of amazing that all they had to do was copy the casting and they tried and failed at that.
That's really all you need to know. hehehehe
For everyone's reference, the Aisin FBT-001 for $116 on Amazon is the exact same thing that I pulled off my engine. They were a perfect, identical match, so no need to skimp on brand. The Aisin (OEM) is almost free on Amazon.
